Author Topic: usb port in radio control location (or other USB locations)  (Read 1215 times)
OfflineLokey1
  • Newbie
  • Country: us
    I have a new to me 2013RT and was wondering if anyone has installed a USB outlet in the cover that goes over the radio control cutouts on the left of the fairing. Obviously it would need to be waterproof and align with one of the eight holes where the switches would go (if one had a radio). I discovered these holes when inspecting the bike and snapping the cover off. Sadly, I didn't get it snapped back into place properly and lost it somewhere on the freeway. A new cover set me back 30 bucks. I did get a USB connector that goes into the BMW socket on the left of the fairing but its a bit obtrusive and too far away from my phone mount. I think a better solution would be a dedicated USB port where the radio switches were. Possibly there's even a better solution for a dedicated usb port (for an android phone or camera). That said, even two USB ports would be a nice addition.
    « Last Edit: 2017-05-19 14:12:24 by Lokey1 »
    2013 R1200RT- the last of the oilheads
    OnlineDavid.
    • Hero Member
    • Country: gb
      • Model/year: R 1200 RT / 2012 (Twincam)
      What diameter are the holes (8 off) in the panel for the radio switches.
      « Last Edit: 2017-05-19 15:19:23 by David. »
      OfflineLokey1
      • Newbie
      • Country: us
        The radio button holes are 23.25 mm
        OnlineDavid.
        • Hero Member
        • Country: gb
          If a USB outlet cannot be found which will fit into the 23.25 mm dia. radio switch hole, could the cover be drilled to suit & the holes beneath adjusted accordingly.
          Something like this idea.
          « Last Edit: 2017-05-19 15:44:37 by David. »
          OfflineLokey1
          • Newbie
          • Country: us
            Yup - I was thinking the same. I hate to modify the stock holes for the next owner (after I'm gone),but if they wanted a radio, they'd be better off buying a bike with one as adding one later could be quite expensive.
            Thanks for the photos!
            OnlineDavid.
            • Hero Member
            • Country: gb
              Could always mount the USB socket here, doesn't look like a professional installation and if removed, can't be hidden by a replacement cover.
              « Last Edit: 2017-05-19 17:51:07 by David. »
              OfflineLokey1
              • Newbie
              • Country: us
                That's a better location for me as I mount the phone next to the GPS mount right now and have to rout the USB cable around a few bits.
                It would be nice to have a connector/mount that used the BMW gps connector and slip on mount/cover and even some of the farkley switches on the left side of the mount.
                I don't plan on ever getting a BMW GPS as google maps works just dandy for my needs. Having all the GPS mount right where I'd rather have the phone is a bit of a bummer and I really don't want to remove the unit.
                Does anyone know if there is a pin-out schematic of the BMW GPS mount or if a connector is available?
                OnlineDavid.
                • Hero Member
                • Country: gb
                  Are you looking for a power supply, if so, have a look at this thread, /index.php?topic=3181.msg32390#msg32390
                  OfflineLokey1
                  • Newbie
                  • Country: us
                    Thanks David, yeah, I found that link as well and is a great source for 12v.
                    That said, as I think more about it (dangerous),I'd really like to cook something up that would use the GPS mount which I will never use and is in the way of my current clamp-on phone mount.
                    There's a nice snap on cover over the GPS pinouts which I believe I could mount my phone to using neodymium magnets (I already do this in my vehicles and it works great).
                    If I could find a good diagram of the pinouts that's not in German, and possibly the female connector that would fit inside the cover, that would be sweet. I'm thinking I could modify the cover and add a very short mini USB which would be wired to the correct pinouts and have a very useable set-up.
                    Here's a shot of the pins I am referring to (pic borrowed from google)
                    I'll be away from my computer for the rest of the week but will be checking back in as soon as I can in case someone comes up with some suggestions.
                    « Last Edit: 2017-05-19 21:36:11 by Lokey1 »
                    OnlineDavid.
                    • Hero Member
                    • Country: gb
                      Would some continuity checks between the 3 pin power plug and the GPS mount pins solve the mystery.
                      I believe the red wire is +ve and the black wire is -ve, centre purple wire not needed.
                      https://i239.photobucket.com/albums/ff120/canadianbc/Advrider/208E5E33-4553-41DB-A3DF-817E59B973E0.jpg
                      « Last Edit: 2017-05-19 21:56:54 by David. »
                      OfflineLokey1
                      • Newbie
                      • Country: us
                        I suppose I could use a meter and just start testing the pinouts as that's what I'm trying to achieve - a connection at the gold pins directly on the GPS mount.
                        The plan would be to find the proper connector that would fit those gold pins and modify the cover to have the opposite connector. From that, I would fashion a mount that would hold my phone and either have a very short mini USB cord or a mini USB hard mounted to the cover.
                        Snap the phone to the cover, snap the cover into it's cradle on the stock GPS mount. I know it sounds like a lot of work just to get power to a phone but it makes sense to me.
                        OnlineDavid.
                        • Hero Member
                        • Country: gb
                          A connection at the gold pins directly on the GPS mount.
                          It'll be very interesting to see if a cover (female) is available to fit the pins (male).
                          OfflineLokey1
                          • Newbie
                          • Country: us
                            So far, I've had zero luck and may end up making a simple connector that touches the correct male pins just to power the phone.
                            Mini-B pinouts are easily found on google.
                            Here is the closest diagram I have found - sadly it's lacking the labels for the pinouts. I'll just find the 12v and ground with a meter.
                            https://s25.postimg.org/5pgjhm4lb/connectors_Nav_IV.jpg
                            OnlineDavid.
                            • Hero Member
                            • Country: gb
                              Yes, saw that diagram too, it's not very clear and when you read the appropriate thread about it, it's all very confusing.
                              I read somewhere that it's only 5v at the pins, something inside the mount reduces it from 12v.
                              « Last Edit: 2017-05-23 15:53:31 by David. »
                              OfflineLokey1
                              • Newbie
                              • Country: us
                                Just checked 'em - nothing over .06 when it's running. zero when it's not.
                                There may be some internal stuff going on that needs two pins connected to change output to another one but without a diagram, I have no idea and the choices are nearly endless if I were to try some guessing.
                                Without the diagram (possibly quite proprietary) I'm in low doubts.
                                Oh well.
