Author Topic: Warming Up Before Riding  (Read 876 times)
OfflineMillman
  • Newbie
  • Country: us
    • Model/year: R1200RT/2016
    « on: 2017-10-12 05:06:32 »
    Hi everyone!  Do any of you put your bike in neutral on the side stand and start it up to let it warm up before you ride?  I did this yesterday and noticed a lot of exhaust vapor and smell from the bike. Temp was about 50f and damp outside. Just wondering if this is normal. I haven't done this before.
    Greg
    OfflineT6pilot
    • Sr. Member
    • Country: us
      • Model/year: 15RT
      Re: Warming Up Before Riding
      « Reply #1 on: 2017-10-12 05:16:59 »
      Generally climb on bike, hit the starter, then put on helmet and gloves. About a minute before riding off, easy on rpms till temp gauge shows some heat
      OfflineGDD
      • Newbie
      • Country: au
      • 2016 R1200RT, MT-01, XS650, Tuono 1000R, FLSB.
        « Reply #2 on: 2017-10-12 06:22:29 »
        Never.
        Fuel injected motors should not need "warming up", but if it makes you happy....
        OfflineOur Gee
        • Sr. Member
          « Reply #3 on: 2017-10-12 07:45:03 »
          Same as GDD, never, no need, pointless.
          OnlinePickaxe
          • Jr. Member
          • Country: gb
            • Model/year: R1200RT LE MY 2018
            « Reply #4 on: 2017-10-12 11:21:45 »
            You should warm an engine up as quickly as possible without revving it hard before its reached normal operating temperature. Best way is to ride it ASAP after starting it.
            OfflineMillman
            • Newbie
            • Country: us
              « Reply #5 on: 2017-10-12 12:35:05 »
              Yes I normally climb on and get going. Just thought the smoke was moisture because of the temp and wet conditions. Thanks.
              OfflineTaz
              • Jr. Member
              • Country: gb
                • Model/year: R1200RT LE 2016
                « Reply #6 on: 2017-10-13 07:51:07 »
                Many times I have read advice that said start the engine and let it idle for 30 seconds so that the oil circulates around the engine. Then ride it but do not rev it to the red line until the engine has fully warmed up.
                Works for me.
                OfflineOur Gee
                • Sr. Member
                  « Reply #7 on: 2017-10-13 08:19:06 »
                  We used to have a nearby neighbour who's early morning routine was to push his Jap 1000cc Multi complete with aftermarket end can out of his garage dressed in slippers etc, start the engine then retire back inside to appear again about 10 minutes later all kitted up and ready to go. This seriously pissed off just about everyone within a couple of hundred yards. I diplomatically approached him to point out the annoyance he is causing to his neighbours and his reply was something like "sorry mate, but you have to let the oil get around the engine you know". Still, as the saying goes, "ignorance is bliss" (no offence intended to anyone contributing to this thread).
                  OnlineDavid.
                  • Hero Member
                  • Country: gb
                    • Model/year: R 1200 RT / 2012 (Twincam)
                    « Reply #8 on: 2017-10-13 10:34:11 »
                    Warming up the engine before starting off must be a throw back to the 80's & Japanese multi-cylinder bikes.
                    My 1980 Yamaha XJ650 certainly needs to be "warmed up" before riding.
                    The Owner's Manual states, "To get maximum engine life, always "warm-up" the engine before starting off. Never accelerate hard with a cold engine!"
                    "To see whether or not the engine is warm, see if engine responds to throttle normally with the starter lever (CHOKE) turned off".
                    To this end, I always start the bike, let it warm up until the choke can be fully closed & responds to the throttle.
                    OfflineLevisp
                    • Hero Member
                    • Country: gb
                    • RT1200 LC SE
                      • Model/year: RT1200LC / 2014
                      « Reply #9 on: 2017-10-13 10:46:08 »
                      Maybe a different approach would be get on his bike and ride off ! 10 minutes later come back and point out if you had been a real thief then he would have lost his bike and the insurance company would not have paid out. Sorry but leaving a bike unattended with the keys in is just bloody stupid. Twat !
                      OfflineITB
                      • Newbie
                      • Country: us
                      • 2016 R1200RT
                        « Reply #10 on: 2017-10-13 19:12:46 »
                        Switch on.
                        Wait for tach/speedo needle dance.
                        Push starter.
                        1st gear.
                        Ride off.
                        Onlinegogs01
                        • Sr. Member
                        • Country: gb
                          • Model/year: R1200RT LE 2017 MY
                          « Reply #11 on: 2017-10-13 20:45:36 »
                          Switch on.
                          Push starter.
                          1st gear.
                          Ride off.
                          Works for me.
                          I haven't done the warm up thing since my bikes had choke levers and kick starts - and then it was the bare minimum, just to make sure it wasn't going to die on me at the first junction.
                          For boxers with separate gearboxes, warming up makes even less sense since everything else needs to get up to temperature too, so getting under way as soon as possible is the way to go - just take it easy for the first five minutes.
                          Onlinesimbo
                          • Sr. Member
                          • Country: gb
                            • Model/year: R1200RT 2011
                            « Reply #12 on: 2017-10-13 22:08:22 »
                            Old habits die hard  :)  I like to rev the shit out of my Harley whilst it warms up too, that really annoys the neighbours  ;)  I just leave the mutt on the drive in case any theives or grumpy folk come round lol.
                            Don't be so serious!! And never let it take away from the fact you have semen between your tits when writing advertisements ;-)
                            OfflineBlueboy
                            • Newbie
                            • Country: 00
                              « Reply #13 on: 2017-10-14 01:00:19 »
                              Works for me.
                              Best answer !
                              Sent from my SM-G920W8 using Tapatalk
                              Blueboy
                              OfflineJBnAZ
                              • Newbie
                              • Country: us
                                • Model/year: R1200 RT 20114
                                « Reply #14 on: 2017-10-14 06:49:40 »
                                The thought that came to mind was, from what temperature is the bike starting from? If it's seriously cold, yes, warm up the bike a bit to allow the lubricants and other fluids to warm up some.
                                If it's not seriously cold there is no need for any extended warm up period.
                                With that context, I let my bike idle for 30 or so seconds and I don't romp on the throttle until the motor is fully up to operating temps.
                                The next question may be how to warm it up. Riding gently is equally effective as is letting it idle in my opinion.
                                BTW, I treat all my vehicles in the same manner, not just the RT.
