Author Topic: Help with grips  (Read 723 times)
Offlineptong971
  • Newbie
    • Model/year: 2016 R1200RT
    Help with grips
    « on: 2018-03-11 23:46:22 »
    I just bought a 2016 R1200RT from a friend.  I am traditionally a Goldwing driver.  I use Kuryakyn Isogrips because I have hands the size of oven mits.  These dinky little grips on the R1200RT are causing me issues.
    Please provide me with directions to aftermarket products that I can install to drastically increase the radius/diameter/circumference of the stock grips on the R1200RT.  And STOP now if you are going to suggest grip puppies.  I had them on my Wing and they are don't do shite.
    I also need suggestions on products for lowering footpegs and for good highway pegs.  Otherwise I'm all set.
    If you want, e-mail me at paultong971@gmail.com.  I appreciate your help.  These dinky little grips are killing my hands and carpal tunnel issues.
    -Paul
    Offlinetemesvar
    • Full Member
    • Country: ca
      • Model/year: 2008 R1200RT
      Re: Help with grips
      « Reply #1 on: 2018-03-12 00:10:58 »
      I would suggest tennis racquet over grips. They offer good grip, and you can roll them as thick as you wish.
      Also, there are the fishing rod tapes. Some riders like them, I never tried . Just a suggestion. And yes, I don't
      like them grip puppies or buddies either, but many here swear by them. Is just a matter of taste.
      Lowering pegs, Wunderlich has some, as well as Knight Design
      http://www.knightdesignllc.com/
      None is cheap! Good luck finding what you are looking for.
      Offlineca1ic0cat
      • Newbie
      • Country: us
      • New R1200RT after the HP4 proved impractical....
        Re: Help with grips
        « Reply #2 on: 2018-03-12 01:00:38 »
        OURY "road" grips work pretty well but you'll have to cut the end.  Suburban Machinery makes a good foot peg lowering kit.  I've got both.
        OfflineT6pilot
        • Hero Member
        • Country: us
          • Model/year: 15RT
          Re: Help with grips
          « Reply #3 on: 2018-03-12 05:02:10 »
          Excel Cycle Werks makes a O-ring kit to enlarge grip diameter
          Offlineptong971
          • Newbie
            Re: Help with grips
            « Reply #4 on: 2018-03-13 02:36:28 »
            Thank you, very helpful.
            Offlineptong971
            • Newbie
              Re: Help with grips
              « Reply #5 on: 2018-03-13 02:41:40 »
              Thanks, I might check them out.
              Offlineptong971
              • Newbie
                Re: Help with grips
                « Reply #6 on: 2018-03-13 02:42:12 »
                I'll check out that Suburban Machinery.  Thanks.
                Offlinepwbike
                • Full Member
                • Country: au
                • 2014 R1200RT
                  • Model/year: R1200RT 2014
                  Re: Help with grips
                  « Reply #7 on: 2018-03-14 09:20:53 »
                  I have big hands too, and I found the grips on my 2014 LC uncomfortable. The diameter is too small.
                  I fitted Grip Puppies and that solved my problem with discomfort.
                  I find that I drag footpegs too often with the standard setup, I can't see how the bike would be very ridable or enjoyable with lowered footpegs.
                  I'd be looking for a higher seat option before I'd think about lowering the footpegs. I have my seat on the high position and can easily do long days of 700 km or more and all day on the bike with only fuel and brief lunch stops.
                  Peter
